Updated pics of the S-type...
Old Jun 11, 2002 | 05:06 PM
Jason kiDD's Avatar
Default Updated pics of the S-type...
Here are the pics..
Yeah its dirty so what
So there is some truth. My engine is just stamped with the H22a and then a serial number below it.. Dont me what it means though...
Old Jun 11, 2002 | 05:25 PM
singlecam screamer's Avatar
Default Re: Updated pics of the S-type... (Jason kiDD)
it looks good what is it a cx,hopefully i'll be swapping my motor into my cx
Old Jun 11, 2002 | 05:37 PM
Jason kiDD's Avatar
Default Re: Updated pics of the S-type... (rudy 94 si)
Maybe... hehe Wont tell till its all said and done..
Old Jun 11, 2002 | 06:04 PM
Jonathan_ED3's Avatar
hey kiDD, what shifter assembly did you use? Do i need to get the entire assembly, along WITH the entire length of lines that come with it? I haven't been able to find out exactly what it is i need. Looks awesome though has she been driven yet?
Old Jun 11, 2002 | 06:14 PM
Jason kiDD's Avatar
Default Re: Updated pics of the S-type... (hot_EF)
I used the shifter and linkage from my Accord.. The shifter is kinda big though compared to the Prelude one Newman uses.. But it still works..
And no she is still on jackstands waiting for DSS to send me the right driver side axle.. I do recommend them though the axles are badass..
Old Jun 11, 2002 | 06:22 PM
cool.....thanks. I'll just get a Lude shifter assembly
About the radiator fan....Do you know what the max depth would be when using a Del Sol VTEC radiator? I don't want to buy one to find out it's too deep. I'll be using the HCP kit too so we should have about the same clearance depths. Could you help me out with that at all?
Also, how much were your DSS axles all together? you're using the stage 2's, yes?
Old Jun 11, 2002 | 06:52 PM
Jason kiDD's Avatar
Just get an EX/SI or Delsol radiator. They are all the same and no I havent measured it for max depth or anything.. Just know that it replaces the stock fan and it works..
And I have Stage 3's... Was apart of the groupbuy a while ago..
[Modified by Jason kiDD, 11:32 PM 6/11/2002]
Old Jun 11, 2002 | 06:58 PM
i'm about to order a Del Sol VTEC radiator....so get the fan with it to? it's thinner than the standard CX radiator fan i'm using now?
Old Jun 11, 2002 | 07:08 PM
Jason kiDD's Avatar
No dont get the stock del sol fan because it wont fit.. Get a slim fan from autozone, pep boys, or whomever... 12' inch perferrably.. So it'll be a little smaller than the radiator itself.
Old Jun 11, 2002 | 07:12 PM
hm..i'm confused. a min ago you said just get an EX/SI or Del Sol fan, and now you're saying not to. did you mean get a Del Sol Slimline fan or what?
Old Jun 11, 2002 | 07:32 PM
Jason kiDD's Avatar
Sorry my typo..
Old Jun 11, 2002 | 07:36 PM
okay.....so let me get this straight. Del Sol VTEC dual core radiator with like a pep boys/autozone 12" slimline puller style fan. yes?
Old Jun 11, 2002 | 07:49 PM
Jason kiDD's Avatar
Yes
Old Jun 11, 2002 | 09:05 PM
l's Avatar
l
i was hoping to see an S type JAG
not a TYPE S motor
all n all cool deal
Old Jun 12, 2002 | 04:50 AM
VTECVillain's Avatar
Ahhhh the almighty H Deuce Deuce! This is next on my list of projects. Which motor mounts did you go with, looks like HCP? Does the left tranny mount/bracket need relocated and welded in?
Old Jun 12, 2002 | 05:15 AM
Jason kiDD's Avatar
Default Re: Updated pics of the S-type... (IM ALL SHO)
lol then this wouldnt be a Honda forum and yes the mounts are HCP, however there was no welding needed just a little cutting from the tranny side bracket.. Fairly easy to do.
Old Jun 12, 2002 | 06:20 AM
StockTeg's Avatar
Looks good.
Old Jun 12, 2002 | 11:43 AM
Jason kiDD's Avatar
Default Re: Updated pics of the S-type... (StockTeg)
Thanks..
Old Jun 12, 2002 | 01:17 PM
HybridKOOP's Avatar
I just began the same swap with an OBD2 engine/harness/ecu.. into a 1992 VX hatchback.
Do you suggest I use a P13 ECU, and remove the OBD2 harness off the motor and use an OBD2 GS-R harness instead? Seems like the OBD2 Prelude harness is not going to plug into the shock tower plugs like a GS-R would... what do you think? Thanks..
- Louis
Old Jun 12, 2002 | 03:14 PM
Jason kiDD's Avatar
Default Re: Updated pics of the S-type... (HybridKOOP)
Nah just convert everything over to ODB I.. Its simpler that way since the Civic harness is ODB I anyways.. And just add whatever plugs you need to it.. You will need to get an ODB I distributor though.. After that its fairly easy,,.
Old Jun 12, 2002 | 03:52 PM
Newman's Avatar
New User
Yeah, mine is a Prelude shift linkage that came with my swap. Any of them will work.....
Old Jun 12, 2002 | 03:57 PM
Jason kiDD's Avatar
Default Re: Updated pics of the S-type... (Newman)
If you need any other pics for your site just let me know, Newman...
Old Jun 12, 2002 | 04:30 PM
so let me get this straight, when i get a prelude shift linkage, i have to get that shifter assembly and get both cables attached to it? how far do those run? are they hard to pull out of the car? anybody got a Prelude assembly already out that i could buy from you?
Old Jun 12, 2002 | 11:03 PM
Newman's Avatar
New User
Yup... I have an extra cable linkage w/shifter from another JDM H22A swap (92-95 swap). Email me if you want it.
Old Jun 13, 2002 | 10:33 AM
Propulsion's Avatar
hey, I thought the type-s all had ATTS and wont work w/ a EK swap?
