Help! B18c1 into ej/95 coupe...power steering and obd.
Help! B18c1 into ej/95 coupe...power steering and OBD.
I'm working on swapping the b18c1 into my 95 coupe, the engine has no power steering(everything gone from location on b18 engine). Will the power steering from my EX motor work on the integ motor? If not, I'll have to find a power steering unit.
The engine is a 96, which I believe has obd2. I have a 95 ecu, which is obd1 and which I want the motor to run as. What needs to be done to the motor to enable it to run as an obd1...hacking/disconnecting wires etc?
TIA!
[Modified by Thagreybomber, 5:03 PM 6/11/2002]
[Modified by Thagreybomber, 5:04 PM 6/11/2002]
[Modified by Thagreybomber, 5:05 PM 6/11/2002]
TIA!
Re: Help! B18c1 into ej/95 coupe...power steering and obd. (Thagreybomber)
No you need a b series power steering pump. I have a pr3 one for sale. If you want it hit me up.
Re: Help! B18c1 into ej/95 coupe...power steering and obd. (erniecars)
so all I'd need is the pump, nothing else? All other hoses and such should be good to go from the d16? Let me know how much for the pump....I bought the AEM power pulleys and would hate to return it, I already have the alternator pulley on.
you may also need a power steering pump mounting braket if you dont already one. Email me if you want the pump. killebrewj@hotmail.com
I'll get back at you by the end of the week. If the guy that sold me the engine doesn't have the p/s and other stuff anymore...i'll look you up. Thanks for the help!
okboi24
11-06-2009 12:44 PM
