What do you need to drop b18b in a 96 civic cx?
Motor mounts. a/c compressor? wiring etc......
I need everything that it will need down to nuts and bolts.
Thanks.
Thanks.
Re: What do you need to drop b18b in a 96 civic cx? (b18c ya)
You need a 99 civic si driver side mount(bolts into the block below the cam sprokets). A 99 civic si rear tranny mount, a 94-97 del sol ac bracket(p54 if I remember correctly) Front tranny mount will be intergra. Rest are stock. You will need a obd2 motor for easy wiring, the shift linkage out of a 94-on teg, all the fluids and some misc things to get a dealer. I got all the wiring info from Trey's website(jpec tunning? forgot the website ) If you get a USDM engine you will have a cel code 91. If you get JDM don't worry about this.
