Friend needs help w/swap!!
A friend of mine is putting a b16a2 from a 99 Si donor car into his integ LS....what all does he need from the Si??
and I know people will ask why don't he just do an LSVTEC swap..cuz i'm gettin his LS engine....bwahahaha....
Re: Friend needs help w/swap!! (95hbMatt)
well besides exactly what u said, thats a big waste of his time. LSs with bolt ons run the same as SIs. but at least u get his old motor.
what yr is his teg? u will need ECU, a new block mount (he needs to keep his off his B18), new rear tranny mount (keep B18 also). tranny and wiring harness depend on the yr of the car.
Re: Friend needs help w/swap!! (BoOsTeD_eK)
well he got the Si motor for exchange of his b18b and cash...then i bought the b18b from the other guy....
well...good for you...sucks for your friend... I had a 96 Integra Ls with a jdm b16a2.....SUCKS!! He will definitely feel it.
Re: Friend needs help w/swap!! (hondaatwsu)
Re: Friend needs help w/swap!! (JV)
Why in the hell would you put a B16 in a Teg. Rediculous.......
Re: Friend needs help w/swap!! (Jedi Master)
Bah...he can use all of his stock mounts.
Bah...he can use all of his stock mounts. You were right about using the driverside mount bracket on the block, but that's it. He can use his ls engine harness and add the wires, but he cant use the si harness, thats only good for the plugs. So if his car is 99-00, he can use the ecu, injectors and what not. If his car is anything before that, he cant use the ecu unless he gets an adapter harness. If his car is obd1, I would suggest pulling the injectors off of the ls motor and using those.
_______
Why would you put a b18b in an ex? Your car probably weighs the same, if not more than an integra.
Yes, my 2400lb EX weighs more or as much as a 2700lb Integra. Get your facts straight ********......
so if his car is before 99-00 he can't use the Si ecu?? but to make it work he'll have to get the obd1 to obd2 harness right?! if so, where can he buy this harness from??
and gutted down to 2300lbs would mean no AC, no interior and no heater core. integs r pigs, even just the shell. i highly doubt its 2300 unless mentioned above.
Bragging, who the **** is bragging?
B18B 95 Civic EX
15.1 @ 91.5
15.1 @ 91.5
[Modified by Jedi Master, 8:20 AM 6/14/2002]
Banned
My friend's integra weighs 2300lbs. And that's a fact! Dont talk ****, you dont have much to brag about yourself.
What year is his Teg.....?
No ******* 3rd Gen Integra weighs below 2550lbs unless it's "gutted"......
[Modified by NWP4LIFE, 12:41 AM 6/15/2002]
