rear disc conversion for 96 civic
Will rear disc brakes from 91 teg bolt up to 96 civic??
wondering if i can take the 91 teg trailing arms and bolt it up to the civic
any info is appreciated thanks
Re: rear disc conversion for 96 civic (whitelightning)
i have personally tried this swap on my 97 civic.. when i slapped on some 17's, the rear stuck out jus enough to rub on my fender well.. so i had to swap the disc out for my regular drums, and it fixed the problem. so jus to be safe, i would pull one from a 94 + integra or 99-00 civic si.. i have swapped out my rears from a 94 integra and it looks ok, but i can't tell b/c i have stock 15's.. jus my 2 cents..
Re: rear disc conversion for 96 civic (AzN_J_SpeC)
did you use the civic LCA or integra when it rubbed the fender well?
thanks for the info
thanks for the info
anyone know if the trailing arm AND its bushing from the teg will bolt up to the civic???????
i have a 94 gsr rear brakes in my 97 civic. i know 94-00 acura integra and 99-00 SI are direct bolt-on. i used my stock control arms both upper and lower and used the gsr parking brake cables. i'll soon get a 99-00 Si brake booster, proportioning valve and master cylinder. peace
Re: rear disc conversion for 96 civic (SilverCIVIC96)
I have 99 civic hb DX and I purchased the rear rotors, calipers, and control
arms from a wrecked Si for $100. The guy that I got them from told me that
I didn't need the Si proportioning valve or the MC and Booster. All I need to
buy are the brake line hoses and the e-brake cables. I got both of those for
$100 brand new at O'Rielly's. I think later on I will upgrade my MC and Booster
though. Is that all I need to complete this conversion?
lexluther
03-15-2009 04:29 PM
Steven.
07-27-2008 08:45 AM
