b16 2nd gen crx code 9
Old Jun 4, 2002 | 08:41 PM
nsxmatt's Avatar
Default b16 2nd gen crx code 9
Started the crx tonight for the first time since the install came up with a code 9, cly sensor?? Checked the distributor per service manual with a volt meter, all good. The engine started up and sputtered and missed a little then threw the code. The plug cly. had water in them when we got the engine so I cleaned out the water about 3 weeks ago, well as much as I could. It still had a little moisture by the plugs so I removed the plugs and cleaned them and am letting it sit and air out over night. Would this cause the code 9 and the missing??
Were waiting till thursday for the int. shaft from a teg so we can put on the drivers side axle so we hope the engine will be running smooth for the test drive! Thanks in advance!
Old Jun 5, 2002 | 05:23 AM
nsxmatt's Avatar
Default Re: b16 2nd gen crx code 9 (nsxmatt)
ttt help?
KDvtec5757
Aug 17, 2008 05:18 PM
XEF-9X
Jan 4, 2003 08:10 PM
done
Oct 8, 2002 03:37 PM
