Check out my Motor Mounts - diagnosis needed..
1 Post
Sorry for the crappy pics , bad digi cam + bad lighting = these pics. anyway this has been sort of a concern with me, my timing side mount (the metal things that stick up) seem to be bent, well one at least. Im not sure if they are supposed to be upright or not.
I fit the Timing Side Bracket on, and it slid on perfectly. So do you think I have a problem or not.
*PICTURES*
*PICTURES*
Re: Check out my Motor Mounts - diagnosis needed.. (navin)
They should be perfectly straight, if that is what you are asking. But if it holds the mount on there securely, you should be fine.
1 Post
Re: Check out my Motor Mounts - diagnosis needed.. (Jedi Master)
They are straight up - but the one that is farther back sits toward the left. I mean the bracket slides through the it and fits fine and lines up with where the bolt goes. So do you guys think this is fine?
1 Post
Re: Check out my Motor Mounts - diagnosis needed.. (KAMiN)
Gonna try that tommorow.. Thanks for the time Tony and Kamin. w00p last day of school tommora
It doesn't look normal. I guess if it works then just leave it be. I would probably replace it though. Better safe than sorry.
1 Post
Re: Check out my Motor Mounts - diagnosis needed.. (acuracing)
How would I replace that. HOw can i take that mount off anyway. I just hope its not like welded on there or something.
It treads in. You need two nuts on top of each other and use that to take the studs out. Studs were like $7.
[Modified by 97hb, 10:22 PM 6/7/2002]
Is your mount bent also? If you need I have an ls mount (pretty sure its the same) with the studs already in it. You pay for shipping.
gottabfast
02-18-2009 04:35 PM
O16581724 5 2 5
05-30-2005 10:35 PM
