B16 cams SUCK!!!! Should I just get some ITR's?
Right now I have b16 cams in my LS/Vtec motor. The power seems to REALLY die off arround 7300 RPMs. Will ITR cams pull hard all the way to 8,000? Will the ITR cams help my low and midrange power at all?
Re: B16 cams SUCK!!!! Should I just get some ITR's? (InfamousRS)
yea mine shuts off at about 7500 too
i think the ITR/CTR cam/valvetrain setup is good to about 8500 but i might be wrong
Re: B16 cams SUCK!!!! Should I just get some ITR's? (KAMiN)
My whole valve train is ITR except for the cams(inner & outer springs, retainers, and valves) . And my head is port and polished and has a 3 angle valve job, at this point I think these 1st gen b16 cams are holding me back!
i have ctr cams in my itr motor - pulls (i should say did pull-long story) strong until 8400
Re: B16 cams SUCK!!!! Should I just get some ITR's? (AzN_Flava)
The 92+ B16 cams would be a little better. The best choice would be some ITR cams or maybe even get Toda or JUN.
Re: B16 cams SUCK!!!! Should I just get some ITR's? (B16CRX)
the diffrence isnt worth the money from b16a (first gen) and second gen cams
just get an ITR setup
Better yet get the Skunk2 Stage I cams. People who had both the Type R cams and Skunk2 Stage I's say the Skunk2's are better, even though the specs are almost the same.
Or if you have cash, get the Stage II's with the valvetrain ugrade.
Re: B16 cams SUCK!!!! Should I just get some ITR's? (fork)
CTR intake cam is better, but it is only 3 degrees more duration. I have heard that the 00+ ITR cams are only 1 degree difference. Unless the CTR cams are close to the same price I would just go with ITR.
Not disagreeing, just saying you have to make sure the price difference isn't more than the performance difference.
Re: B16 cams SUCK!!!! Should I just get some ITR's? (vntperformance)
man stop being cheap and get some skunk 2 s_2!
vnt
vnt
vnt
vnt
GS-R Cams:
Intake- 230 degrees of duration, 10.7mm of Lift
Exhaust - 227 degrees of duration, 9.4mm of Lift
17 degrees of overlap
2000-2001 ITR Cams:
Intake- 240 degrees of duration, 11.5mm of Lift
Exhaust - 235 degrees of duration, 10.5mm of Lift
25 degrees of overlap
CTR Cams:
Intake- 243 degrees of duration, 11.5mm of Lift
Exhaust- 235 degrees of duration, 10.5mm of Lift (Same as ITR Exhaust cam)
28 degrees of overlap
Skunk2 Stage 1 Cams:
Intake- 252 degrees of duration, 11.58mm of Lift
Exhaust- 249 degrees of duration, 10.9mm of Lift
You can clearly see the Skunk2 Cams is the most agressive cams out of the GS-R, ITR, and CTR cams.
Go with the Skunk2 Cams. I had ITR's before, but traded them plus something else for Skunk2's...
Re: B16 cams SUCK!!!! Should I just get some ITR's? (b18c1 dc2 R)
The thing is, I don't want to spend all that money on skunk cams right now, the stage 2's are deffinatly in the future though, when I rebuild my bottom end.
Last night I met a guy in town with a b16 swap in his EG. He has CTR cams, I started talking to him a bit, and he said he was selling his car to this guy who doesn't know a think about cars for like $10,000. I asked him if he would like to swap out his CTR cams for my b16a cams plus some cash sence the guy hes selling it to probably wouldn't know the difference. He said he would probably do that if I did all the work. He said he would probably do it for $200!!!! He also has some JG cam gears on there that I may beable to get out of him as well.
I have one question, will I have enough valve clearence with my PR4 (LS) pistons, and b16a head (milled .020)? I really don't want to start knocking valves into pistons!!!
maybe u have 1st gen JDM cams that were outta a auto. possible other problem might b lack of fuel in the top end. might try those b4 saying its the cams. theres alot of those auto cams runnin around.
Re: B16 cams SUCK!!!! Should I just get some ITR's? (RK)
So if I drop Stage 1s in my gsr motor...i won't have to upgrade the valvetrain??
Re: B16 cams SUCK!!!! Should I just get some ITR's? (hondaatwsu)
ok well with mugen chip u should b fine, i dont think u had it listed in the sig.
