What sensor is this????
Old Jun 6, 2002 | 10:32 AM
JD_B18CDX's Avatar
Default What sensor is this????
It has an orange cap, has 3 wires, and mounted on the engine block below the exhaus manifold.
http://mywebpages.comcast.net/jdefensor2/Sensor.JPG
I dont get a CEL but this sensor is not hooked up.... what is it for???
[Modified by johnd, 2:33 PM 6/6/2002]
[Modified by johnd, 2:34 PM 6/6/2002]
Old Jun 6, 2002 | 10:36 AM
B_CRUZ!'s Avatar
Default Re: What sensor is this???? (johnd)
i dunno. is that a 96+up B18C1? did you get it from IAS?
Old Jun 6, 2002 | 10:59 AM
Mentat Ghola's Avatar
It could be your Knock sensor or your Crankshaft Position sensor. if its not giving you a code I presume its the knock sensor. If the CPS wasnt hooked up youd be in a heap'a'trouble. So, my final answer is........KNOCK SENSOR.
Old Jun 6, 2002 | 11:44 AM
markpaco's Avatar
It is likely a water temp sensor as that is where the stock water gallery (aka freeze plug) plug goes in. What you have there is likely an aftermarket add-on. I would not worry about it.
Old Jun 6, 2002 | 11:45 AM
JD_B18CDX's Avatar
Default Re: What sensor is this???? (B_Cruz)
It is a 95 B18C1... and yes its from IAS.
I dont think its a knock sensor because the knock sensor is below the intake manifold.
Crank position sensor is at the crank or camshaft.
I could be wrong on my assumptions.
Any other ideas????
Old Jun 6, 2002 | 11:48 AM
t's Avatar
t
water temp?
Old Jun 6, 2002 | 12:34 PM
B_CRUZ!'s Avatar
Default Re: What sensor is this???? (HatchedSI)
definately not a knock sensor. i had a feeling it was from IAS cause mines has the LH on it too by the block number and tranny.
Old Jun 6, 2002 | 12:59 PM
tSuperbike69's Avatar
Man that is not a sensor at all it is a block heater. You need the cord to plug into the wall so you can keep your baby warm on those cold nights when shes sleeping.
Old Jun 6, 2002 | 02:36 PM
JD_B18CDX's Avatar
Default Re: What sensor is this???? (tSuperbike69)
U r right... could be a block heater.
How do we verify?
Its not a temp sensor because I dont get a cel.
[Modified by johnd, 6:38 PM 6/6/2002]
Old Jun 7, 2002 | 12:53 AM
tinkerbell's Avatar
How do we verify?
you are trippin'
t..
SuperBowser707
Dec 4, 2012 07:49 AM
hoezee
Oct 6, 2008 10:40 AM
SC94DB8
Oct 22, 2002 11:16 AM
CM-R
Mar 29, 2002 12:34 AM
