ls swap in ek???'s
ls swap questions...help me please
hey guys i just got an ls swap done to my 99 civic hb. and i have some questions. one question is under the plastic of the cams there is a hole cut out where there is a bolt into the block. is that normal.
a sensor on the intake manifold on the drivers side has no sensor going into it. whats up with that..is there supposed to be one going into it?
where does the first o2 sensor by the exhaust manifold go. i dont see any holes for it.
also could you guys give me some pics of what a 98 ls engine looks like. the more detail the better.
thanks for the help
[Modified by phatcivic99, 1:09 PM 6/8/2002]
thanks for the help
Re: ls swap questions...help me please (kb58)
actually no i went to the pepboys around my house and they were all out.
oh thanks for your help oh great acura tech.
p.s. can i have some real help please.
thanks
[Modified by phatcivic99, 5:43 PM 6/8/2002]
thanks
Re: ls swap questions...help me please (phatcivic99)
hmmm..sounds like you have a 98 LS...the biggest and noticeable difference you can tell is the valve covers..the 90-96 have small block type pattern..kinda like the older ZC the 97-up have no blocks..and look like the CRV engines too..the other diff would be OBD1 to OBD2
your O2 sensor near the exhaust manifold should go the cat..if you have one already attached then you might be OBD2..i think..my 2cents..
helms manual works wonder cant go wrong for 60bux
http://www.helmsinc.com
