00si --> 96ls converter harness
Re: 00si --> 96ls converter harness (Chuji)
I can make that for you but why would you want to run the '00 Si ECU. That ECU is not a good ECU if you want to go fast.
I would recommend switching to OBD1 and running a chipped P28 if you have a DOHC VTEC B-series swap in your '96 LS.
Email me at kenji211@tampabay.rr.com
Since you are local it will be easy to pick it up. I am in Tampa also.
-kenji
-kenji
http://jdmfan.com/technical/performance/obd2-to-obd1/
you can try that out..but i would go with a OBD1 ECU...either GSR or chipped P28
hope that helps..good luck
Re: 00si --> 96ls converter harness (kenji)
would it be possible to make a harness adapter for a 96 ex harness to a 00' si ecu? I just did the swap and found that one of the plugs doesnt come from the engine on the si motor.. so my car is still just sitting there
jorgejam2001
09-25-2009 08:47 AM
sevenfc
07-23-2009 05:57 PM
SkRiBLaH
12
06-23-2006 05:43 PM
