Code 23 (knock sensor)..can't get rid of it..HELP
Old Jun 9, 2002 | 04:37 PM
jdmciviceg's Avatar
New User
Default Code 23 (knock sensor)..can't get rid of it..HELP
A friend of mine put a built B18C1 12.5 to 1 compression swap into his 90 CRX. He is running a PW0 chipped ecu. Ever since the swap has been completed, it has thrown a code 23 (Knock Sensor). He tried changing the knock sensor and it did not help. He also tried running the wire from the knock sensor straight to the ecu to make sure the wiring was correct. It didn't help. Anyone have any suggestions on what could be the problem?
Old Jun 9, 2002 | 07:23 PM
BABYGIRL ITR's Avatar
Default Re: Code 23 (knock sensor)..can't get rid of it..HELP (jdmciviceg)
detonation is a possibility. is it knocking?
Old Jun 9, 2002 | 07:40 PM
jdmciviceg's Avatar
New User
Default Re: Code 23 (BABYGIRL ITR)
It doesn't seem to be, but it must be since it threw the code. I personally think its the ECU, but he wanted more input from honda-tech. Any other suggestions?
Old Jun 9, 2002 | 07:56 PM
Default Re: Code 23 (jdmciviceg)
what octane is he running? he might want to retard the timing a little. unplug the knock sensor and see if it throws the code still.
noob23
Aug 27, 2004 03:59 PM
Trygge
May 14, 2004 09:16 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
hondaspeder
Jun 19, 2003 09:21 PM
jdmciviceg
Jun 10, 2002 11:39 AM
