does my '00 jdm B20B have oil squirters?
Does a 2000 Jdm' B20B have oil squirters or the bosses in the block for them? Has anyone put them in a B20 block?
Re: does my '00 jdm B20B have oil squirters? (DADOHCturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DADOHCturbo »</TD></TR><TR><TD CLASS="quote">Does a 2000 Jdm' B20B have oil squirters or the bosses in the block for them? Has anyone put them in a B20 block?</TD></TR></TABLE>
No. I don't belive you can add them either. No real "need" like you might think. Research some more on LS/B20 rods and you will see what the solution is for the lack of oil squirters.
Re: does my '00 jdm B20B have oil squirters? (Stinkycheezmonky)
ok not pin oilers, the ones im talkin about are tapped into the block and are like small nozzles. I know Most if not all B-series Vtec blocks have them and some K-series have the bosses but not tapped ,The B18A/B dont, i would say the B20 has no provision.
Suspetise...
1 Post
You're correct, the non-VTEC motors accomplish that oil squirting via the holes in the rods. Why do you want them anyway? If it's that big of a deal, get a VTEC block and sleeve it.
Do you know how long i have to leave that in my oven , if the temp is @ 375*,to pull the sleeves out? j/k disassembling the block and drilling and tapping way easier than me paying to sleeve a block, my B20 is already rebuilt and i didnt think of it before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DADOHCturbo »</TD></TR><TR><TD CLASS="quote"> Do you know how long i have to leave that in my oven , if the temp is @ 375*,to pull the sleeves out? j/k disassembling the block and drilling and tapping way easier than me paying to sleeve a block, my B20 is already rebuilt and i didnt think of it before.</TD></TR></TABLE>
It doesnt work like that....the ones in my block are actually capped when using aftermarket pistons and rods there really is a need anyway......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky »</TD></TR><TR><TD CLASS="quote">The rods ARE the squirters. Search.</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">
Research some more on LS/B20 rods and you will see what the solution is for the lack of oil squirters.</TD></TR></TABLE> No Results Found
Your search for ls/b20 rods returned no results.
Please try different search criteria or a different data set.
Anyway im going road racing with this block and thought it may help dissapate some heat,cause the engine has around 12:1 c/r.
Suspetise...
1 Post
There are plenty of non-VTEC block guys running on track without those. Kevin Helms' B20VTEC H1 car is one of them. My B20B doesn't have them either. Neither do any of the B18B/B20B H4/H2 cars. You'll be fine.
As for searching, try different terms, and try selecting the archives. There's a channel in the rod that squirts up on the wrist pin and bottom of the piston (at least on the wrist pin, 99% sure it's also onto the piston).
Edit: As an example -
» Search Results
Your search for b20 rods returned 240 results.
Modified by Stinkycheezmonky at 12:23 AM 1/1/2008
» Search Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DADOHCturbo »</TD></TR><TR><TD CLASS="quote">aren't the squirters to cool the pistons not the rod.</TD></TR></TABLE>
The function of the oil squirters is to cool the piston skirts, yes. Do I think they are 100% neccessary? Not at all. Will they help? certainly. Is your engine going to self destruct without them? No. If its really a concern, you need to consider sleeving a Vtec block. You aren't going to be able to get away with simply drilling and tapping some holes... doesn't work like that, as others have already pointed out.
The Ls/B20 rods have small holes in the intake sides of the rods also. They face the thrust side of the piston skirt which act as oil squirters. This is what I was hoping you would find with a search. Perhaps you might need to search somewhere else other then strictly on Honda-Tech.
carboy_honda
15
01-16-2006 06:27 PM
