What kind of AFRs you running ?
I know there are posts about what AFR you should tune to... I know the answers that everyone gives... but I would like to know what all you DIY tuners are running in and out of VTEC ?
I currently have around 13.2-13.4 out of vtec and averaging 12.8-13.0 in vtec... dropping down to 12.6's from 7k - 8k.
What's your AFRs look like ?
Re: What kind of AFRs you running ? (X2BOARD)
I shoot for 14.5-15.0 for low load partial throttle driving and around 13.3 WOT for a naturally aspirated Honda on gas. Obviously you would be between those depending on the load.
Re: What kind of AFRs you running ? (4piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston »</TD></TR><TR><TD CLASS="quote">I shoot for 14.5-15.0 for low load partial throttle driving and around 13.3 WOT for a naturally aspirated Honda on gas. Obviously you would be between those depending on the load.</TD></TR></TABLE>
same here..
same here..
moderator emeritus
then make it leaner and richer and see which one the engine likes better.
All Motor Mentor
1 Post
Re: (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD »</TD></TR><TR><TD CLASS="quote">Forgot to ask what octane you're running on.
I am running on the low end 90-91 octane (sux for me)</TD></TR></TABLE>
For the most part, the amount of octane you run, doesn't really affect the air/fuel ratios you tune for as long as it's pump gas and not race fuel, ethanol etc. The octane you run has more of a direct effect on the amount of timing you can tune your engine for.
Re: (an2ny888)
I have a PLX and AEM, I think Innovate was the most consistant in the comparision I saw. Still does not matter, if your engine runs the beast @13.7 on your guage, run it there. Different compressions and intake manifolds like different numbers, there is no one answer.
