F22B2 piston to valve
Old Jul 24, 2009 | 05:14 PM
96halx's Avatar
Default F22B2 piston to valve
Building a 100mm stroker. Using stock rods and off the shelf pistons, the piston will be out of the block by .0984 inches. If I just bore out the cumbustion chamber .1 inch in it, will that cause any piston to valve issues with me using a bisimoto level 2 cam? Cam specs are:0.400" valve lift on the intake, 0.372" exh; 222 deg duration on intake and 225 deg exhaust at 0.040"
Plan on running an 11:1 CR, was needing a -3.4cc dome(dish), will be slightly larger with the reduction in combustion chamber volume.
I know this is kinda noobish, and you probably need more info, but just let me know and I'll tell you.
I know that the motor should be physically checked for this, just want to make sure it's not obviously wrong.
Old Jul 25, 2009 | 11:09 AM
96halx's Avatar
Default Re: F22B2 piston to valve
anyone?
racebum
Jan 15, 2009 10:50 PM
FATBOYeg6
Mar 17, 2008 02:17 PM
vtecmonster001
Nov 16, 2006 08:16 AM
fortynineR
Jun 30, 2004 08:37 AM
HotRodTeg
Nov 17, 2003 06:26 AM
