No oil on the dipstick after adding oil
Whats up people... I just finished changing the HG on my JDM B18C. After putting all back together I added 4 quarts of oil, then I checked the dipstick so see the oil level. I was shock to see that there was no oil on the dipstick. I dont know was going on.. can some one help me out!
ps
I all so had the car on front jack stands when I add the oil, but when i took it of the jack stands, the dipstick remain the same with no oil.
ps
I serve phở for my babies
Re: No oil on the dipstick after adding oil
there's no oil puddle on the ground is there? If it's a HUGE puddle of oil, then you put on the headgasket wrong.
if you just ran the motor, let it sit for a minute or two before you check the oil so it can make it's way back to the crank case
There is no oil leak ... no puddle of oil anywhere. im gonna losen the oil plug to see if there is oil in the oilpan
I check the oil pan... and there was oil coming out of the plug when I loosen it up. How does someone block the oil drain holes
