LS Rods/Crank in B18C5??
Forgive me if this info is somewhere already, I searched and could seem to find anything.
I'm building my brothers motor (turbodcx) which is a B18C5 with 84mm Darton sleeves. I have RS machine 11.5:1 pistons and I'm debating using an LS crank in this motor, so if I do will I need LS rods or can I use the GSR/ITR rod? Will my pistons work with LS rods?
Kinda thinking like an LS/VTEC but using the B18C block? Is the LS crank just as strong?
Let me know your thoughts...
Touching My Member
Re: LS Rods/Crank in B18C5??
You'll be adding more stroke so technically it will be a 2 liter. I believe your compression will be closer to twelve depending on how much the head and block have been milled. Yes, use LS rods with those pistons. you should be ok. I went the other way and used an ITR crank in a B20 block and used ITR/GSR rods.
Need the slightly shorter ls rod, unless you want to reduce the combustion chamber size thereby increasing cr. Or you could have deck extended a couple mm's. The cranks on my b18 say p72 on them, I assume they put these on all there motors.
Good point on the squirters, never thought about that.
I really don't have a power goal yet being this is truly my first Honda build, I'm a Ford guy But I'm mainly building the car in rememberance of my brother Brian, it was his car and he was shooting for 900whp with the build but unfortunately when he was in the hospital theives stole many of the parts from his garage so I'm gathering up everything piece by piece to finish the car.
