LS vs GSR engine carpartment hose connection.?
Curious if anyone has used a thermostat housing from a non-vtec bseries onto a vtec bseries.??(LS->gsr).. the whOle connecting pipe along with the thermostat housing..
Doing a build... 01 gsr bottom end with a 95 gsr head.. Swapped the stock gsr intake manifold for a skunk2.. the factory gsr style has a metal tube from the connecting pipe to the heater core, i want to eliminate that metal tube.. Factory manifold has mounting location, which the skunk2 does not. I’ve been staring at the helms for awhile now and it seems like the LS work and do me very will..
Has anyone done this.? Or even thought of this.??
in the fsm/helms.. 10-3
Re: LS vs GSR engine carpartment hose connection.?
HAve not done it but, If the LS one does not have the hose that you dont want to have then it should be fine. They are both Bseries blocks so if it doesnt bolt right up it probably be easy to make it happen.
Give it a try.
Give it a try.
im thinking so too.. but a little bit more response be nice.. but thanks for yA comment nick97hatch..! i will mOsdEf try it out tho...
i didn't get a chance to post some images up yesterday.. but here it is.! the images, so yA know what im talking bout.!! so .?? im not going to be running the obd1 gsr oil cooler, but yA see the difference.. less hose.. less mEss and hAssle.. hAHA.. :D
alright.. i got sOme updateS and i was able to get what i wanted achived.!! sweet'Ish and awhOle lot cleaner then the gsr oem style...
i got rid of that metal pipe already.. its from the thermostat housing straight to the heater core now...
