all motor with fuel pressure problem
ok, turn the key on and my fuel pump sends fuel to my rail and injectors with about 60psi on the gage and as soon as the fuel pumps shuts off, the psi gage goes back down to zero, check all lines, injector seals, no leak anywhere...... it's a walbro 255 internal fuel pump im using. what could be the cause if theres no leak to be found?
All Motor Mentor
1 Post
Re: all motor with fuel pressure problem
my stock pump drops pressure when I shut it off. I have removed the pulse absorber/dampner from the fuel rail inlet, not sure if that has an effect on pressure dropping after I shut the car off.
Fuel pumps normally have a check valve in them so fuel pressure does not bleed off after the key is turned off. I don't know if a Walbro pump has one though.
Ok, since I have a Walbro, I decided to check it.
1) Battery disconnected
2) Connected the battery - no change in pressure
3) Put the key in the position right before cranking - pressure goes to 40 for a second then back to zero
4) Put key in the off position - pressure still at zero
So in my case after activating the pump's 12v line, it primes the fuel rail for a second, then shuts off sending the pressure goes back to zero.
Is there something 'wrong' with this behavior on the Walbro?
