Rocket Motorsports - Gets a Flow Bench
Rocket Motorsports - Flow Bench
In our efforts to improve the Honda Head we have purhcased this superflow SF110 to do flow testing of ports, valves, manifolds.
I am looking to flow some K series heads so if you are interested and have a stock K series head I would like to flow that for testing purposes.
BTW: That's Ej6andslow aka ladies man.
Re: Rocket Motorsports - Gets a Flow Bench (aemcivic_02917)
Been doing some heads for my dealers and some friends with satisfying results.
The bench will be used to experient with some port configurations and testing valves and stuff.
Banned
Re: Rocket Motorsports - Gets a Flow Bench (BERT-O)
Heads in the mail! It'll be one its way to your doorstep very soon
hopefully it will make it on there
Modified by Irishweird00 at 10:32 PM 4/7/2004
Congrats to many sleepless nights, frustrating days, and proud new owner of one of the best and worst things to happen to a head porter. Good Luck!!
Re: Rocket Motorsports - Gets a Flow Bench (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR »</TD></TR><TR><TD CLASS="quote">Cute, a little 10" one. Real men use 28" ones
Although, something is better than nothing!!</TD></TR></TABLE>
Maybe your donation didn't make it in time and not everybody is made of money.
Glad to see you got your new toy finally Rocket.
Re: Rocket Motorsports - Gets a Flow Bench (Big Teggie)
good luck, i'm sure you'll suceed with this also, maybe when my motor see 'phase 2' you'll be my port and cam suplier
LOL. Supposedly only good for go-karts and lawnmowers but it should be accurate if one measures certain conditions.
There are conversion charts like the one on Alaniz website that translates 10" flow numbers to 28" and is farily accurate.
Head's comments are probably from experience
Re: Rocket Motorsports - Gets a Flow Bench (Rocket)
i personally think that the numbers mean nothing, as long as u can tell if your are helping or hurting flow at different lifts. My old teacher had a "homemade" flow bench out of a 5hp wet\dry vac, he never knew any numbers but he could always tell in a percentage if the head flowed better or worse. Congrats on the new bench
We shall see how well Alaniz's charts transpose 28" numbers. My head, which was done by him, was put on a 28" bench before it was 'reworked' to perform better, so I have back and white data. I'll dig up the sheet sometime and share.
Having said that, using SOMETHING is way better than going by LOOKS. What are you going to be testing? Chamber design? Valve angles? Port design/size?
Re: Rocket Motorsports - Gets a Flow Bench (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">
Robert, its about time. Actually you may not be happy with the 110. Let me know.</TD></TR></TABLE>
I'll just plug it into a 220v outlet and instantly turn it into a SF220
From what I've seen the 10" to 28" conversion is fairly accurate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR »</TD></TR><TR><TD CLASS="quote">Having said that, using SOMETHING is way better than going by LOOKS. What are you going to be testing? Chamber design? Valve angles? Port design/size?</TD></TR></TABLE>
There are parts on the Honda head that likes work and there are some parts that don't really do much flow wise. Also will probably get some velocity probes and pressure map the ports.
Re: Rocket Motorsports - Gets a Flow Bench (advanracing62)
The 220 volt is a good idea. Try 440. Yes the conversion is good used it for a long time , just thinking you may run out at 10 inches, and no this is not a John Holmes post, I switched because th e 110 was gettig maxed on the B series.
