lsvtec setup
i am trying to compare my lsvtec setup to others just to make sure i am straight for driveabilit hp numbers would be nice what works what does not work ne problems you encountered here my setup
block
99b18b
ac blockguard
arp mainstuds
endyn blockgirdle
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73ao pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
stock crank pulley
drivetrain
gsr tranny
ls th gear
itr lsd
act stge 3 6 puck ceramic
itr 11lb flywheel
flp clutch line
head b16a2
port matching on tb & manifold
ctr cams
65 mm str tb
aebs manifold
h22 vtec 310 injectors flowed/cleaned
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
p28 with custom dynologged mapping thru speedymotorsports .com
ge cam gears
p.s everything that wears was replaced build on a 50k block
Modified by 99lsvtecauto at 4:11 AM 5/31/2004
block
99b18b
ac blockguard
arp mainstuds
endyn blockgirdle
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73ao pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
stock crank pulley
drivetrain
gsr tranny
ls th gear
itr lsd
itr 11lb flywheel
flp clutch line
head b16a2
ctr cams
65 mm str tb
aebs manifold
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
ge cam gears
