VSS Sensor ( Variable Speed Sensor)
Old Aug 30, 2004 | 01:07 PM
nenacivic23's Avatar
Default VSS Sensor ( Variable Speed Sensor)
I was wondering how do you know if your VSS sensor is working?
Old Aug 30, 2004 | 02:41 PM
87sivtec's Avatar
Default Re: VSS Sensor (nenacivic23)
What car/ecu do you have? Are you triggering a code? Is your speedo working?
Some more info would help and you will get more responses to this in the tech section.
Old Aug 30, 2004 | 03:07 PM
Default Re: VSS Sensor (87sivtec)
I HAVE A 92 HATCH... ECU IS A HONDATA I HAD JUST PUT IT IN.. IT'S WEIRD THE CAR JUST DOESN'T MOVE WHEN I PUT IT IN TO 4 TH GEAR.. ( wHEN I'M GOING DOWN THE 1/4 MILE IT'S FINE UNTIL I PUT IT IN 4TH THE CAR DOESN'T TURN OFF, THE ENGINE KEEPS RUNNING IT'S JUST THAT IT DOESN'T MOVE... DO YOU THINK IT MIGHT BE THE VSS SENOR?
Old Aug 30, 2004 | 03:18 PM
Dan GSR's Avatar
vss is vehicle speed sensor
and sounds like you broke 4th gear
variablevalve
Aug 17, 2020 10:41 AM
madnad
Sep 18, 2018 06:49 AM
mrpaccmann
Feb 8, 2010 12:41 PM
thannon2
22
Jan 20, 2009 08:04 PM
thannon2
Jan 16, 2009 01:59 PM
