dzminiz's D16 Engine Rebuild Kit
Old 10-08-2004, 07:18 AM
dzminiz's Avatar
Default dzminiz's D16 Engine Rebuild Kit
i spun a bearing so im lookin toward a rebuild kit, as long as i didn't bend anything, so new bearings, oil pump, ANY1 Know Where To Find A Kit??
Thanks
dzminiz is offline
Old 10-08-2004, 08:14 AM
lohatch's Avatar
Default Re: d16 rebuild kit (dzminiz)
i dont know if anybody sells a complete rebuild "kit" but you can pick up some ACL bearings from a couple different distributors on this site, one of them being EARL. you can pick up a gasket set and oil pump from your local honda dealer. hope that helps a little. maybe somebody else has some pointers about where to pick up gaskets for a better price.
lohatch is offline
Old 10-11-2004, 06:36 PM
dzminiz's Avatar
Any1 Have Any Links or More Info For Me??
THANKS
dzminiz is offline
Old 10-12-2004, 09:48 AM
dzminiz's Avatar
exactly what other parts would i need??
dzminiz is offline
Old 10-24-2004, 06:05 PM
MiG-21 superfan
builthatch's Avatar
http://www.importperformanceparts.net offers alot of rebuild parts, like higher-flowing oil pumps and bearings
http://www.hondaautomotiveparts.com is a decent source for parts, i know their sister site acuraautomotiveparts.net offers honda part for 25% off OE list....
builthatch is offline
Old 10-24-2004, 06:10 PM
CallMeJesus's Avatar
Default Re: (dzminiz)
if you spun a rod bearing, the crank is going to need to be checked out, to see if you ate the journal up.
i can sell you a package deal that will give you a great basis for an all motor d16. if all you need is bearings, pistons, rings, pins, and a gasket kit, off the top of my head i could sell it for $500.
CallMeJesus is offline
Old 10-24-2004, 06:51 PM
Banned
LSVTEC 91 Civic's Avatar
Default Re: (CallMeJesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CallMeJesus &raquo;</TD></TR><TR><TD CLASS="quote">if you spun a rod bearing, the crank is going to need to be checked out, to see if you ate the journal up.
i can sell you a package deal that will give you a great basis for an all motor d16. if all you need is bearings, pistons, rings, pins, and a gasket kit, off the top of my head i could sell it for $500.</TD></TR></TABLE>
Why would he need new pistons?
LSVTEC 91 Civic is offline
Old 10-24-2004, 07:08 PM
MiG-21 superfan
builthatch's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Why would he need new pistons?</TD></TR></TABLE>
for a bump in compression he could select a set of OE pistons from another d, such as p29 or something-----
Old 10-24-2004, 08:38 PM
S13sGA2DUMP's Avatar
Default Re: (builthatch)
dude here's some advice, drop the d-16 and why dont you get some B series motor? sounds like some extra horse power, reliable, and you get more street credit dawg, haha im kidding, you got to think what is more worth your money
S13sGA2DUMP is offline
Old 10-24-2004, 09:06 PM
MiG-21 superfan
builthatch's Avatar
Default Re: (S13sGA2DUMP)
full d16z6 build for $2500 with 90% OE honda parts that will net you around 20-25 more whp and 20+ more ft/lbs than a b16 swap...or, b16 swap with all the associated parts for $2500.....
Old 10-31-2004, 07:29 AM
d16z6 build for $2500...ill tell you what, ill do that build for $1500, all day long, any day of the week including God's day.
i built a d16z6 for a thousand. it runs nearly 14:1, eats up b, h, and k series engines with a jg engine dynamics cam, and TB.
i love b series, but there is a lot to be done with a d16. but the next trick is droppin a fully built turbo h22a runnin 11:1 with 16lbs into a 1988 crx si shell.
Old 10-31-2004, 08:47 AM
MiG-21 superfan
builthatch's Avatar
to make over 150 whp reliably out of a sohc vtec, I have found you need...
p29's @ .5mm over with rings- 250
Crower 2 or 3 cam- 325
Springs/ TI rets- 320
ARP rod bolts- 50
Bore, mill/deck, balance, shot-peen rods, valve job- 500
portwork- free, if you know what you are doing
or
portwork- 500
bearings, gaskets, WP/t-belt- 250
Clutch- 325
y8 intake mani- 50
BBK TB- 250
or Type R TB- 150
Header- 300-600
PowerFC- 650+250dynotime
or
Hondata- 295+250 dynotime
or
chipped p28- 150
This is assuming you already have the complete engine and it is not damaged, your fuel pump is up to the task, your injectors are balanced/ flowing properly, and already have obd1 harness plugs so you don't need jumper harness....
PS- sure, you could cut many many corners, but every extra mile you get out of the setup is worth it as is every little HP...
Old 10-06-2005, 02:06 AM
NA tangy_b16's Avatar
i just did the same thing looking for same info and if you find anything please let me know, i need to get my car back on the road
thanks tangy..
NA tangy_b16 is offline
Old 11-10-2005, 08:53 AM
dzminiz's Avatar
Default Re: d16 rebuild kit (NA tangy_b16)
wow this topic is OLD&gt;
I just swapped in a gsr
Wish i would've stayed sohc (moneywise)
or bought another car and built a motor as the money was availbale.
just my .02
dzminiz is offline
Old 03-09-2018, 06:06 AM
honda_tec's Avatar
Default re: dzminiz's D16 Engine Rebuild Kit
Hey guys. yeah this is really old post but i thought i just share it anyways for the people that are still looking for a rebuild kit. http://ebay.to/2FEhEWY Bought this rebuild kit and it did the job for what i need it for.
honda_tec is offline
whattheduck
Transmission & Drivetrain
08-06-2023 11:14 AM
itr1235
08-12-2006 05:07 AM
egerdahl
01-28-2006 02:00 AM
Yuleluder
04-22-2003 06:07 PM
karmannghia
04-30-2002 10:15 AM
Quick Reply: dzminiz's D16 Engine Rebuild Kit
