Hesitation under load / temporary loss of power. MAP or dist?
sometimes when driving under partal throttle, the engine hesitates and there is no power, but if i let my foot off the gas completly , then put it back it works as normal.
map sensor problem or distributor cap?
or somthing else??
or somthing else??
Re: Hesitation under load / temporary loss of power. MAP or dist? (SkRiBLaH)
I would think MAP sensor based on the sporadic arrival of the problem.
what mod's do you have.......
I had the same problem, but I've got high compression ~ 11.4cr.......
I changed my o2 sensor, cap/rotor, wires and fuel filter and they didn't do ****!
mine turned out to be......., I had wrong timing and the wrong spark plugs (to hot)
Greg1995Civic
10-23-2014 07:54 AM
