Piston Valve Clearance
Old 04-25-2005, 02:23 PM
racinategra's Avatar
Default Piston Valve Clearance
I was wondering if anyone out there new what amount of clearance is neccessary to safely operate. I have recently installed COMP stage 2 cams in my b16 head and due to the amount of lift took them out to be safe. The clearance was 40 thousandths on the exhaust and 60 thousandths on the intake. I am runnin a b18 bottom end with CTR pistons. I was told I need to buy stiffer valve springs and retainers to safely run the car. Anyone have some ideas?
Old 04-25-2005, 02:33 PM
DonF's Avatar
Default Re: Piston Valve Clearance (racinategra)
.040 is to close on the Ex. valve. .060 on the intake is just manageable.
Old 04-25-2005, 05:33 PM
rjay8604's Avatar
Default Re: Piston Valve Clearance (DonF)
It's those damn CTR's. They have a taller compression height than the other b-series pistons.
Just for anyone's informaiton the compression height is the distance from the pin center to the deck of the piston.
Old 04-28-2005, 04:43 PM
so do you think it would be fine with stiff valve springs or not?
Old 04-28-2005, 05:17 PM
rjay8604's Avatar
Default Re: (racinategra)
Hmm, recheck with the CTR's in. Then you can decide.
Old 04-28-2005, 05:22 PM
DonF's Avatar
Default Re: (rjay8604)
No, reading is a requirement to build engines.
Old 05-01-2005, 04:16 PM
im not building the engine myself. the shop that is said it should be fine with stiff valve springs. i am running the stock b16 cams now, but the clearance problem is with my Comp Stage 2 cams
Old 05-01-2005, 05:14 PM
DonF's Avatar
Use their recomendations, and check the warranty they give you. With B-16 you are prob. ok, but not with .040.
State.of.Prime
10-17-2010 01:43 PM
VtecLsEater
02-27-2009 11:02 AM
Twisted Image
02-10-2009 09:38 PM
hu
07-12-2006 10:08 AM
Tyson Ballou
11-25-2001 07:50 PM
Quick Reply: Piston Valve Clearance
