220 WHP set up, what cams/header
i got a LS block right now with ITR pistons/rods. GSR girdle.
im getting a b16a head. ordering my rocket valve train package sometime this week. and taking it to the machine shop.
my question is what would be a good set of cams for the motor. i dont want anything to crazy, this will be a street driven car/daily driver.
also looking for a header. ive read the SRZ header test thread. im really digging the RMF.
also do yall think my setup would even be 220ish WHP worthy?
also the car will be tuned VIA uberdata/chrome
Re: 220 WHP set up, what cams/header (Beau Gotti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beau Gotti »</TD></TR><TR><TD CLASS="quote">also do yall think my setup would even be 220ish WHP worthy?
Probably not, but good luck though
Skunk Pro1's or Toda C2's would be my cam choices.
Beau look at my motor to se what it takes to make 230whp in GA.
that setup might make 200whp-205whp with a ported head. without ported head, look towards 190-195whp.
Skunk2 Pro1s or Skunk2 Pro2s or M22xx are the ONLY cams i would be looking at to buy for an NA car.
On a 1.8l, the RMF hands down. have not hasd anyone beat one yet
Re: 220 WHP set up, what cams/header (VtecKiDD)
it will be pretty hard to reach that goal without some pretty big cams and a free flowing head.
for a header get the RMF for sure and just look around and some dynos of cams and just see what suits your needs and power goals. bc4 pro2 m22's etc. are all good cams that will make the power as long as the rest of the motor is up to the task. you live pretty close to the guy that can answer all your questions ie VtecKidd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">
The new M24x's are pretty sick too
B18a block honed,bored .20 over,micropolish,blueprinted,balance,hot tanked etc..
JE pistons (with b16 head CR = 12:5)
Eagle Rods
STR block guard
UR crank pulley
B16 oil,water pump
GSR timing belt
B16 rod bearings
B16 main bearings
Golden Eagle 82mm lsvtec kit
B16 head honed, hot tanked, 5 anlge valve job...NO P/P
Crower stage 3 cams
Crower dual retainers
Crower retainers
ARP head studs
Skunk 2 intake manifold 65mm
Password JDM Intake manifold gashet
B16 throtle body Bored 65mm
Cold air intake 3'
JDM 4-1 header
Apexi Na exhaust 2 1/2 piping
Omni test pipe
UR alt. pulley
STR cam gears
B16 tranny
Exedy stage 1 clutch
Exedy 9.5 lbs flywheel
ITR LSD
Skunk 2 harness
P28 ecu
MSD ignition
RC 310 injectors
Aem F.R
B&M F.P.R
Hondata S100 tuned
thats my set up and i don't even think i will hit 205 whp
Eagle Rods
STR block guard
UR crank pulley
B16 oil,water pump
GSR timing belt
B16 rod bearings
B16 main bearings
Crower stage 3 cams
Crower retainers
ARP head studs
Cold air intake 3'
JDM 4-1 header
Omni test pipe
UR alt. pulley
STR cam gears
B16 tranny
ITR LSD
Skunk 2 harness
P28 ecu
MSD ignition
RC 310 injectors
Aem F.R
B&M F.P.R
Hondata S100 tuned
maybe 220 was a little steep of a goal. the head will be ported and polished, as well as the usual valves, springs, retainers, and such.
ive been reading on the m22's and i might go with them, since ill be using rocket valve train anyway.
ill be running a JDM DC 1 piece header, until this summer/spring.
im moving my goal to 190 WHP all motor. still got alot of little things to get, convert fully to OBD1, chipped ecu, conversion harness blah blah blah
thanks for the opinions.
Re: 220 WHP set up, what cams/header (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Todd,,what are toda c'2'S?</TD></TR></TABLE>
Toda has revamped the Toda A's and Toda C's; the A's now have spec B VTEC lobes and the C's now have 5 degrees more duration intake and exhaust. Hence the new designations Toda A2 and Toda C2.
http://www.todaracing.com/prod....html
Re: 220 WHP set up, what cams/header (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
http://www.todaracing.com/prod....html</TD></TR></TABLE>
Interesting...
Interesting...
Re: 220 WHP set up, what cams/header (rochesterricer)
i would say rocket m24x with rocket valvetrain and what do you know i happen to have that set-up for sell pm for price
adro2333
22
06-18-2004 10:38 AM
