b20 vtec build need to do research
I have bought a b20 block and a b18c5 head with no cams, springs and needs new valves. I was wondering if anyone can give me some info on the build. Also what cams are good and intakes also. I have a lot of questions about the build
Re: b20 vtec build need to do research
here you go bud:
http://lmgtfy.com/?q=how+to+properly+build+a+b20+vtec
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
this thread help me out a lot on my build I hope it dose the same for you
Should b fine. Depending how much power u want. U want more power then bore it out. 82mm is the max to bore, more than that then I recommend aftermarket sleeves.
Yes a b20 is 84mm but the sleeves are weak depending how much power he wants to push, he won't b pushing much power with thin sleeves. I was just sayin since he hasn't mention how much power he wants out of it, that 82mm with 350-400whp is the limit for dd, better b a damn good *** tuner to hold up those sleeves. B20 sleeves are thin and like the max I would go on them are 300-350whp depending on a good *** tune. But I don't know how much power a b20 sleeves can hold. Just my opinion for a dd
And if u read my last couple sentence I said I didn't know how much horsepower a stock b20 sleeves holds.
SORRY gUYS I FOrGoT THIS WAS A b20V lOl. I had mind on b18. Sorry again guys.
Posted by clean rice :You obviously don't know who Uncle Dave is^
Your replies give me headaches
No I don't I'm still learning the ropes as I go too but I do like to be corrected when I'm wrong. It's not like in trying to give bad info I'm tryin to help to the op with some knowledge I know.
Since u posted here y don't u give the op some knowledge
No I didn't say that. I was say on a b18 motor 82mm bore would b the max to bore out. I didn't say anything about 82mm pistons in a b20 block.
Now Clean Rice is one of technical people on here and you really need to listen to what he says as he has been around for a very long time on here and has a very good knowledge base with Honda's.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/p-r-e-stock-sleeve-b20vtec-dyno-3164743/ 2 year old engine hmm B20 sleeves are just fine when they are built and tuned CORRECTLY
I wasn't sayin it in a bad way, some of ur knowledge will help the op. I read some of ur post awhile back and u do good work. I didn't mean it like that if I came out the wrong way
