Need help with b18c5 build
My setup consists of:
p30 pistons
jun3's
ssr header
68mm tb
Is this enough to break 200 whp? If not what else could I do?
p30 pistons
jun3's
ssr header
68mm tb
Re: Need help with b18c5 build (greeneg2.0)
Stock itr which I just got back from machining. Thinking of getting IB intake manifold but don't know if it's worth putting it on a unported head.
Re: Need help with b18c5 build (DCtooD)
wow i didnt think it whould be that high
reason i ask is because im building my c5, and i was debating between p30's and jdm itr pistons
Re: Need help with b18c5 build (01-0720)
im personally getting jdm itr pistons for my itr block... raise the compression somemore with my fully built head.... should be fun enuff!
Re: Need help with b18c5 build (ABCVTEC)
using p30's to bump the comp a little and also the head was milled slightly so it could be a little higher but still under 12.
92integraVTECgsr
03-27-2006 08:09 AM
hott95ej2
09-25-2005 10:35 AM
05 S2K Stoner
42
12-10-2004 09:07 PM
