H22 Swap/Heater Doesn't Work..
Re: H22 Swap/Heater Doesn't Work.. (yangja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja »</TD></TR><TR><TD CLASS="quote">
help me out... i did a H22 swap and then the heater doesn't come on anymore.</TD></TR></TABLE>you did a swap and you cant figure this out? also you need to clear up your question.
Re: H22 Swap/Heater Doesn't Work.. (fastwanabe)
Check the Black valve by the rear mount. check to see if it is not broken and/or the cable is hooked up to it.
Re: H22 Swap/Heater Doesn't Work.. (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">Check the Black valve by the rear mount. check to see if it is not broken and/or the cable is hooked up to it.</TD></TR></TABLE>
yea check that and make sure it is hooked up...its right under the throttle body. I had the same problem after i did my swap and just went to the junkyard and got a new one.
