obd0 motor into obd1 car
i know this is possible but how my mecanic is stuck. should i go to a shop that does engine swaps? are there wiring harnesses out there 2 make my wires connect?
Re: obd0 motor into obd1 car (1992tegRS)
what motor are you putting in? I figure you have a 92 rs. most of the time you just use the stock engine harness and add wires for various sensors and extend some. if you can give more info that would help
use your old harness and use a OBD1 dist and ecu and use the old vss from your old trans. also you can use your old exh man with the old O2 and this is the bulk of it. add wires for vtec and vtec oil pressure
92integraVTECgsr
03-30-2010 05:58 AM
KevronsEG
11
06-28-2002 09:23 AM
