Poly-Urethane Engine Mount Inserts
Old Oct 24, 2004 | 02:18 PM
EM2Civic's Avatar
Default Poly-Urethane Engine Mount Inserts
My friend has a 93 CX hatch with Jdm b18c (gsr) and he is looking into buying some new poly-urethane insert. He ordered the ones made by prothane and he ordered a kit for a gsr. The inserts should fit right?
Modified by EM2Civic at 5:21 AM 10/25/2004
Old Oct 24, 2004 | 08:22 PM
EM2Civic's Avatar
TTTTT
Old Oct 24, 2004 | 08:34 PM
Icey112's Avatar
Default Re: (EM2Civic)
yes i have the same car and swap
Old Oct 25, 2004 | 05:14 PM
EM2Civic's Avatar
Thanks Mods can close now
Old Oct 25, 2004 | 05:20 PM
Icey112's Avatar
all good
Old Oct 25, 2004 | 07:27 PM
doublejz's Avatar
Default Re: (Icey112)
yes, actually i think all (B) dohc inserts are the same. (i think)
Old Oct 25, 2004 | 08:27 PM
Prod's Avatar
Default Re: (doublejz)
nope i know that the b16 and gsr inserts are diff, have a set of each sitting right here
to the original poster i beleive you need the civic mounts since i beleive for an eg you use the lower civic mounts to put the motor in...you should be able to find out 100% if you search
Old Oct 26, 2004 | 07:14 AM
doublejz's Avatar
Default Re: (Prod)
interesting, when i got my ES bushings all the packages said were B series DOHC and i put them in a 93 eg with a b16 - oh well i guess i was wrong for the first time
Old Oct 26, 2004 | 08:44 AM
civicsit's Avatar
Default Re: Poly-Urethane Engine Mount Inserts (EM2Civic)
well when i did the swap in my 95 civic, i used the motor mounts in my car it shuck shuck for a few moths till the broke in now its not bad tho. but that was about 3yrs ago tho when i did my swap.
but when you go to buy the motor mount inserts some of the 92 to 95 mounts are the same as the 94 and up integra. if i am rong tell me. when my swap was done the box said 92 to 95 si/ex modal. i was not at the time thanking about doing a swap tho, but it came out perfect tho. went with prothane mounts.
its one of those things you may have to try them out to see if you like it. i know i love them
95 coupe b18c1
Old Oct 26, 2004 | 08:42 PM
EM2Civic's Avatar
Install should be done in a couple weeks or during the winter season I'll let you know if I can get them in before it goes for storage. Thanks guys.
MurdersV8s
Sep 14, 2006 04:56 AM
RICE POLICE SIP
Jan 7, 2005 03:09 PM
92CivicSiR2
Jul 31, 2004 10:18 AM
absolut b18
Jul 1, 2003 12:38 AM
