what fuel pressure for a b16 block with gsr head
mostly stock
just wondering so i dont blow it up with the raised compression
btw im using b16 rail and injectors
Modified by bleedblue94 at 4:11 PM 10/29/2004
Re: what fuel pressure for a b16 block with gsr head (bleedblue94)
if you have a stock bottom you can use close to stock fuel pressure. I would dyno or use a wideband to see and adjust to be sure
Re: what fuel pressure for a b16 block with gsr head (smart monkey)
well the stock fuel pressure for a b16 is different then a gsr, plus the compression ratio has been raised
Re: what fuel pressure for a b16 block with gsr head (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">42 psi. You'll be fine </TD></TR></TABLE>
hoses on or off
hoses on or off
