could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch?
alrite, i just finished searching and seems like noones really sure. some say it'll fit, some say its too short. i want to know from someone that has actually done it, or seen it fit. not i heard it'll fit i'm hitting the junkyard in the morning and i know theres couple 90-93 tegs there, and most likely no 94+.
TIA
TIA
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (lazyassbrian)
no, you need 94+ shifter linkage, it's different on the 90-93.
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (dohcdelsol93)
Sorry but yes you can use it....I took the shift linkage from my 92GSR and used it on a b16 swap on my friends 92 hatch...bolted up and works like a charm
this is what i ran into when going through the search some yes, some no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyassbrian »</TD></TR><TR><TD CLASS="quote">this is what i ran into when going through the search some yes, some no</TD></TR></TABLE>
the only thing i can say is just try it, it only takes like 10 minutes to put it on and see. sorry i cant help more
Landon
Landon
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (boosted_dc2)
they are different, held next to one another they have considerable differences other than part numbers. I would buy what you know works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17a1teg »</TD></TR><TR><TD CLASS="quote">Sorry but yes you can use it....I took the shift linkage from my 92GSR and used it on a b16 swap on my friends 92 hatch...bolted up and works like a charm</TD></TR></TABLE>
theres your answer. he did tried it out himself and said it works. hopefully he didnt say it for the hell of it. LOL
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (gutted)
They do look different but it will work. I'm running a 92 shift linkage on my 96 gsr civic. Who ever says it doesn't, obviously never tried it.
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (ek99)
i tried it and it works thats what i'm using right now. payed a lot less than what 94+ teg linkages go for
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (b17a1teg)
I agree it will work...
in a reverse fashion my friend used a 94-01 integra shift linkage in a 90-93 integra and it bolted up fine.
cool guy name
Re: could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch? (K@man)
it works, my friend used it on a 92 teg to 92 bubble back
stackz
11-09-2006 06:44 AM
rice4life
08-28-2003 06:43 PM
