swap problem need help asap
Old Oct 24, 2004 | 05:41 PM
bleedblue94's Avatar
Default swap problem need help asap
ok im replacing my b16 for a b16 block gsr head and itr tranny. i just got it back in and went to fire it up but i just cranks and doesnt not fire up, instead it just spins then eventually i hear this kinda futuristic cartoon gun sound like beeeweh. my friend said that one time he saw a semi fire ball shooto out of the exhaust manifold where it would bolt to the mid section (its not hooked up right now) i need help bc i have no clue whats going on
the plugs are soaked and i AM GETTING SPARK so im stomped please help if you can
Old Oct 24, 2004 | 05:58 PM
smart monkey's Avatar
Default Re: swap problem need help asap (bleedblue94)
check to see if you have fuel or spark. also make sure the cam timing is on also
Old Oct 24, 2004 | 06:07 PM
Default Re: swap problem need help asap (smart monkey)
have fuel and spark now im check int timing
mtownsi
12
May 1, 2007 04:31 PM
bleedblue94
16
Oct 29, 2004 06:49 AM
bleedblue94
Oct 25, 2004 09:28 PM
bleedblue94
Oct 24, 2004 07:18 PM
bleedblue94
Oct 24, 2004 05:40 PM
