Running like a bag! (HELP)
Old Oct 27, 2004 | 10:31 AM
BlazeInEk's Avatar
Default Running like a bag! (HELP)
Ok, so my buddy put a 2000 ITR motor into a 2000 Civic Si (American Ex). He also put in a JRSC, upgraded fuel pump, rc injectors, not using the FMU but instead using a conversion harness and a chipped p28, using stock wiring harness. Difficulties that occured include distributor rewiring, 8 pin plug vs. 9 pin plug (no blue tach wire); iac valve rewiring, currently throwing code 14; injector plugs needed rewiring, O2 sensor rewired and thats all I can think of right now. So, the car runs like a bag. Code 14 only affects idle correct? This would cause idle to be erratic? Anyone have any suggestions on what to check/change to hopefully correct the problem. Car starts fine, when you touch the gas it runs like ****, no power and bogs no matter what rpm. Any info would be greatly appreciated. Thanks in advance!
Pat_Ek1984
19
Aug 16, 2018 05:07 PM
pFB
Apr 15, 2010 06:12 PM
adammilad
Jul 27, 2006 12:01 PM
liam821
28
Mar 18, 2004 11:18 AM
