d16z6 wiring ALREADY SEARCHED
I have a 92 dx that im throwing in a d16a6 block with a d16az6 head. I read that the 92s come pre wired for vtec but i couldnt find exactly how they were wired, are they wired from the ecu to the shock towers? I know swapping in a z6 is plug and play except i need to run 2 wires for the vtec solenoid and the vtec oil pressure switch. Where do i run these wires? Do i run them to the plug on the shock tower? If so which slots do i put these wires into? Any help with be appreciated.
BTW: I searched but couldnt find pictures or anything that said where to run the wires.
Re: d16z6 wiring ALREADY SEARCHED (92GuttedHatch)
should be right on the shock tower look for green w/yellow stripe and blue w/black stripe then just add pins on the opposite sides and run them to the selnoid and pressure valve makes sure black wire off pressure selnoid is grouned properly on the water neck if you have any more question email me smokinjoerider@msn.com
EGCIVICKING95
08-30-2011 05:03 AM
