ZC head block combos?
Old Oct 26, 2004 | 07:45 AM
johnpowellcrx's Avatar
Default ZC head block combos?
what heads fit the dohc zc block it has a head with the valve cove bolts in the top center. stock d16 head ? sohc vtec ? newer DOHC ? b16? really any thing that bolts up and if so what kind of profomance would each have?
Old Oct 26, 2004 | 10:58 AM
Katman's Avatar
Default Re: ZC head block combos? (johnpowellcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnpowellcrx &raquo;</TD></TR><TR><TD CLASS="quote">what heads fit the dohc zc block it has a head with the valve cove bolts in the top center. stock d16 head ? sohc vtec ? newer DOHC ? b16? really any thing that bolts up and if so what kind of profomance would each have?</TD></TR></TABLE>
None do perfectly, except for the head(s) that are designed for the DOHC ZC block. 100% compatible heads for the DOHC ZC block are:
- the US 86-89 integra head (D16A1 engine)
- the JDM 89-95 DOHC ZC head (first gen & 2nd gen ZC heads)
- and the Euro ZC/Rover head (which is exactly like the JDM ZC heads)
Other than that, there are no other 100% compatible heads that will bolt up to a DOHC ZC block. I hear people in the past have tried to bolt up a D16 SOHC head to a ZC block, but the oil passages don't quite line up and machining need to be done....and of course in the long run its not even worth all the effort & $$$.
It's best to stick with a ZC head on a ZC block.
chris riz
12
Sep 22, 2011 12:34 PM
illcrx
Jun 1, 2005 08:35 PM
91ZCcivicSi
Feb 5, 2005 07:12 PM
wicked2night
10
Sep 25, 2003 02:52 PM
