Jdm b16a(obd1) into ek problem!!!
Hi guys,
I have a big problem about my swap in a civic ek.
The car is a Jdm 97 civic ek originally with a d15b engine obd2a harness. I have swapped a b16a odb1 engine and used the d15b engine harness.I have changed the injectors and using a kenji's jumper and p28 ecu.I used the obd1 distributor and connected the wires to the d15b harness coz the connectors didn't match together.I used a helms manual to match the specific wires together.
The engine is not starting coz there is no spark
I have some questions to ask:
Does the b16a with p28 ecu start without the crank flacution sensor?
If i connect a direct supply on the coil and eliminate the oem wires,will i have spark on the high tension leads? ( just to try)
Please i need big help from you guys as usual
Thanks in advance
Thanks in advance
Re: Jdm b16a(obd1) into ek problem!!! (JDM97R)
Hi,
The crank flacuation sensor wires,do i have to wire them to somewhere ( distributor or ecu)?
xkagax
02-14-2006 09:21 PM
