Car not starting need help???
Old Mar 29, 2002 | 10:49 AM
BoM's Avatar
BoM
Default Car not starting need help???
h22a 89 civic
i really just need help on how to test the starter or ignition system.
we just fixed the fuel system, an injector was leaking we replaced the O rings.
now it won't start
how do i know if its the starter?
how do i know if its the ignition spark?
any helps
Old Mar 29, 2002 | 12:13 PM
EGh22aEG's Avatar
Default Re: Car not starting need help??? (BoM)
?????? someone hlep my damn car wont start@!!!!!
Old Mar 29, 2002 | 12:28 PM
Kamin's Avatar
if its the starter, odd are it wont crank.
will it crank?
Old Mar 29, 2002 | 12:31 PM
BoM's Avatar
BoM
Default Re: Car not starting need help??? (KAMiN)
engine doesn't turn over, just hear one click.
Old Mar 29, 2002 | 12:35 PM
poison's Avatar
you can tell if the starter isn't working. if the starter clicks then there is a problem with the starter, the starter motor is not turning the flywheel
Old Mar 29, 2002 | 01:29 PM
BoM's Avatar
BoM
Default Re: Car not starting need help??? (poison)
so we should pull the starter, how do u test that?
Old Mar 29, 2002 | 02:43 PM
CivicEK.PDX's Avatar
look at your starter. There are 2 wires. 1 being a fat one that hooks directly to the battery and the other is a thin one. Pull the thin one and hook a new loose wire to that. Then take the other end of the looose wire and touch it to the positive side of your battery. If it turns and make a noise then you know the starte is ok and it is a internal failure (wiring, relays, ignition.....etc.). Good luck
Old Mar 29, 2002 | 04:13 PM
EGh22aEG's Avatar
Default Re: Car not starting need help??? (CivicEK.PDX)
thanks.........bom we will try that tommorow if you can and see what happens?
Daku99
Jan 1, 2013 09:08 AM
T:rex
Apr 20, 2009 09:34 AM
blueb16-em1
Jun 19, 2008 05:12 PM
SOHC97
Jan 13, 2006 09:34 AM
BoM
Mar 30, 2002 06:52 AM
