Help please VTEC doesn't work
Old Mar 29, 2002 | 05:47 AM
Accord1999's Avatar
New User
Default Help please VTEC doesn't work
I did search on the forum and couldn't find any answer. I have a 97 H22A on a 97 Civic hatch CX. My vtec doesn't work, what could be the problem or solution? I have a check engine but I want to work on the VTEC to kick in first. When it reach 4000 RPM it starts to bug like hitting the rev limiter. I'm using a 96 integra GSR ecu. Help please.
Old Mar 29, 2002 | 06:00 AM
bigblockEG's Avatar
Default Re: Help please VTEC doesn't work (Accord1999)
I think you should be using the h22 computer as well. The fuel maps in the gsr are not enough for the big block. I could be wrong. Talk to this guy Kenji in this forum, I think he might be in the tech forum as well. He can tell you.
Old Mar 29, 2002 | 06:47 AM
Kamin's Avatar
Default Re: Help please VTEC doesn't work (bigblockEG)
use the h22 ecu
the GSR ecu turns vtec on @ 4400~ and the butterflies open at 5700~
Also check your codes! it could be throwing a code that would cause limp mode.
Old Mar 29, 2002 | 07:35 AM
Accord1999's Avatar
New User
Default Re: Help please VTEC doesn't work (KAMiN)
Code is 1, primary oxygen sensor malfunction.
Old Mar 29, 2002 | 08:08 AM
WICKED2's Avatar
New User
i have the same setup 98 civic w/ h22 and i'm using gsr obd1 ecu and ofcrs you have to get a jumper for this kind of setup.the car runs grea... next week i'm going to upgrade my ecu to handata setup.
[Modified by WICKEDII, 5:08 PM 3/29/2002]
Old Mar 29, 2002 | 08:41 AM
Kamin's Avatar
Default Re: Help please VTEC doesn't work (WICKEDII)
code 1 is bad ecu i think.
o2 is 46 or somthing. (had to replace mine after swap)
Old Mar 29, 2002 | 10:25 AM
Jackson's Avatar
off of Katman's site.
Old Mar 29, 2002 | 12:27 PM
Kamin's Avatar
Default Re: Help please VTEC doesn't work (Jackson)
Ive been wrong before
hehe.
Old Mar 29, 2002 | 02:46 PM
CivicEK.PDX's Avatar
you sure you arnt getting a code 0? Also did it run before? MAKE SURE YOUR CONNECTION AND WIRES ARE SNUG IN THE CONNECTORS BY THE ECU.
Old Mar 29, 2002 | 03:52 PM
hybrider's Avatar
Default Re: Help please VTEC doesn't work (CivicEK.PDX)
seems like your in a safe mode
your vtec wont engage due to that mode it is in, clear the CEL first
[Modified by hybrider93, 4:53 PM 3/29/2002]
Old Mar 29, 2002 | 06:03 PM
Accord1999's Avatar
New User
Default Re: Help please VTEC doesn't work (hybrider93)
The car is running and driveable but the vtec doesn't kick in, it bogs. I reset the CEL couple times and keeps on throwing the same code. All the harness are snug. Is there a way that I can by-pass or hot wire the vtec sylonoid to start working again? I brought the car to a performance shop I trust and they found out that I need a OBD1 ecu. But I want your expertise. This webpage helps me installed my H22A with the people on this board guidance.
Old Mar 30, 2002 | 11:01 PM
JALOP B16's Avatar
Hey this sounds ghetto but works on my B16, I ran the vtec solenoid to a switch
because the vss wouldn't let the vtec come on,
If you do this you will get a code 21
the switch must be a always off push button and you must find out when the oil squirters come on or else you will mess up the cams, turn it on when the h22 ecu
would turn it on never before that.
tr0n9h
Sep 13, 2005 06:20 AM
H22A_HB
Dec 16, 2004 02:38 AM
Doubledeala
Oct 12, 2004 08:51 PM
1point7db2
Sep 21, 2004 03:08 PM
ricekiller1
12
Feb 28, 2004 09:34 PM
