1990 integra ls engine
Old Mar 30, 2002 | 02:36 PM
great white buffalo's Avatar
Default 1990 integra ls engine
I just bought a 1990 integra ls with a siezed engine because it was run without oil. Do i definately need to replace it? if so, what are my options?
do i need to replace it with the exact same one?
what are some good used engine buying tips to make sure i don't get stuck with someone elses problem?
thanks for any help,
Old Mar 30, 2002 | 03:30 PM
nickg11111's Avatar
Default Re: 1990 integra ls engine (great white buffalo)
you can replace it with a lot of things. pretty much any b series engine, whether from a civic, another integra, or even a crv if you want... theres a lot of hybrid options.
Old Apr 2, 2002 | 08:16 PM
StorminMatt's Avatar
Unless you completely rebuild the motor you have, you will need to replace it. It can be replaced with the same engine. Or you can replace it with any B-motor. As for maing sure you don't 'buy someone else's problem', this is always a chance you take when you buy a used motor. You could try to have a leak down test. But this is not always feasible when buying the motor. In any case, the newer the motor, the better. And buy from someone who is willing to back up the motor. Even a 90 day warranty is good, as major problems will crop up sooner rather than later.
olddohc
Jan 17, 2011 02:23 PM
khmaiabz
Sep 21, 2008 06:49 AM
panda
Dec 19, 2002 10:30 AM
viCeVerSa
Oct 20, 2002 08:07 PM
great white buffalo
Apr 1, 2002 08:27 AM
