Which parts to use on a b20?
I finally got my b20 motor, this shiit a beauty. i just want to make sure i know which parts i'm getting for the motor. as far as cams, gears, pully, intake manifold, headers, fuel rail, etc. do i jus buy integra ls (b18b) parts?
Re: Which parts to use on a b20? (MugenGTR)
You can use the integra LS b18b intake manifold, fuel rail, injectors, distributor, and some other minor stuff. You'll need the LS ecu as well. You can use 90-93 integra axles and I would recommend a GSR tranny. You shouldn't have to buy LS cams or cam gears unless you wanted to change the head for some reason. Hope that helps a little.
