Code 36 on JDM h22a 95 Prelude ECU?
Former Moderator
Re: Code 36 on JDM h22a 95 Prelude ECU? (SwapGOD)
Code Meaning
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
I didn't see code "36" but maybe there is one? Are you sure you're reading it right?
Short blinks mean one, long blinks mean ten.
I think there's some code 90 somethings too, but I think they are for cylinder misfires.
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
Very familiar with reading codes but lost on this one. 95 Prelude JDM swap in a 96 accord. Everything else is gravy, but this code . Thx for the input though.
There isn't a code 36 listed in my Helms.
Code 63 is for the 2nd O2 sensor. (incase you are reading it backwards)
Do you have that connected? What ecu are you using?
91ef8sir
20
01-29-2013 11:24 AM
