P28-LSVtec oil pressure sensor?
Does the P28 have an input for the oil pressure sensor that is found on a B18B? I'm using the harness from my B18B and the oil pressure switch is yellow/red. This is the sensor that goes into the hole that is used to run oil to the head in an LSVtec swap.
I can't find an input in any of my manuals on the P28, but it isn't mentioned in my Helms Integra manual either.
Since it is a Vtec ECU, does it just use the input from the Vtec oil pressure sensor?
Thanks
Ben
Thanks
Ben
