b20/vtec and the knock sensor...
Old Mar 23, 2002 | 10:15 AM
infamousALLMTR's Avatar
Default b20/vtec and the knock sensor...
I am supposed to have a knock sensor for my vtec ritght? but if im running a p28 chipped do I still need it and if so would I need a diff. ecu? thanks
Old Mar 23, 2002 | 10:36 AM
Trey's Avatar
25 Year Member
Default Re: b20/vtec and the knock sensor... (infamousRRH)
if you are running a chipped p28 then chances are the KS was removed from the proggy....
The ecu will look for the sensor. If it's been removed then there isn't a need to put on on your block.
ninezeroteg
Feb 24, 2009 02:56 PM
ohsnapzafingcu
Oct 21, 2007 09:21 AM
knoj
Nov 16, 2005 04:59 PM
Se-rv-Tak
Dec 2, 2003 09:04 PM
roc
Mar 29, 2003 04:28 AM
