A B18a for my Civic.
I want to install a B18a from a 1993 Integra Ls into my 1989 Civic DX. Will the engine fit? What will I need (mounts, harness,ecu,axles,etc) Any other info will be greatly apreciated. Thanks guys.
Re: A B18a for my Civic. (wankerman28)
hey man whats up, i used to live in terrace! you will need a custom mount kit(hcp,place racing,redshift) plus all the stuff you listed, cable tranny/intermediate shaft/clutch/timing belt/rad hoses/shift linkage etc.. the engine is also gray plug and your civic is white plug, but you can change that. the engine will fit and it will be a blast, but there are wiring changes, dx to si and other little things that come with an engine swap, also you have to use a cable clutch trans not a hydraulic one. the best thing to do is search the net endlessly, you'll find tons of useful info. search here and crx sites are also good. try searching at http://resource.crx.org. look up b18a swap and obd-1(gray plug) to obd-0(white plug) it will give you a good idea of what your options are. you gotta do a search on this board before you post, otherwise you will most likely get no response or get flamed. hope that helps, hit me up if you need more info.
p.s.(how much are you paying for your motor? you can i.m me if you don't wanna say on here. i'm just wondering cause i actually have a 92 complete b18a for sale.
[Modified by speeddave, 2:44 PM 3/22/2002]
91CivicPEI
49
04-06-2011 10:13 AM
jmsplitfyre
14
06-23-2010 10:37 AM
