Code 22 happens all time @ or around 8000 rpms in 4th gear
Location: Toronto, Canada currently residing in ATL, GA, USA
When we swapped my cams out I was overdue for an oil change (Changed yesterday). I think my valvecover is leaking (New valve cover gasket). What else could it be do you think, possible need to clean out the vtec solenoid. I'm hoping I won't have to dig into the block.
Any suggestions.
For those who aren't familiar with my setup: Toda B's, Toda springs, DPR Ti Retainers, JDM B18C(R).
Any suggestions.
Former Moderator
Re: Code 22 happens all time @ or around 8000 rpms in 4th gear (Apex i ITR)
Code list:
Code Meaning
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
So you're throwing a VTEC oil pressure code. RE-check the wiring and the plugs. You had to add that **** to your JDM ITR swap to run a P28 ECU, right?
Code Meaning
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
1 Post
oh yeah, are you running a USDM vtec solonoid or what?
you have to switch to a USDM one if you don't want that code.
Yes it is the USDM Vtec Solenoid. I'll recheck the wiring tomorrow Tom. i've had my car running without a check engine it just starting happening 2 days ago.....out of the blue. Any other insights?
