valve spring/retainer/cam combo for b20vtec...
I have read several posts about valve springs and cam, but I did not find any that really helped me. I have US b20b, first gen b16 head, 10.5:1 JE's, eagle rods, shunk2 chipped p28 with 8800 rev limiter. I am not going to sit on the rev limiter, but I would like to use when I needed. What I am thinking of doing is moving the stock b16 innner and outer springs to exhaust side, then using US itr inner and outer intake springs for the intake side. I will retain the b16 exhaust cam and use a US itr intake cam. Also, I was going to use portflow ti retainers. Anybody see any problems with this plan. Or, should I just stay stock until money allows me to do the head completely. It will be a daily driver and I would like to keep costs down.
Also, should I use a Helms integra (94-00) or civic (96-00).
Re: valve spring/retainer/cam combo for b20vtec... (Jeff C)
well, from what I've heard. The first gen b16 valve springs are not going to do well revving that high. They are older and loose some of their strength. I think your idea is good, just maybe those springs have some excess mileage on them. I would consider getting Portflow springs all around. It wouldn't hurt you any, expecially since you're revving so high. portflow's retainers would be good too.
Re: valve spring/retainer/cam combo for b20vtec... (WAFFLES)
Should I use portflow inners and outers, or just outers, or just inners. This inner and outer spring stuff has me a little confused. Which is combo is better. Also if I use portflows, then is it a really good idea to get both itr cams, or will the the b16 cams be sufficient for now.
92integraVTECgsr
12-29-2020 09:15 PM
