what master cylender will fit on my ek hb ?
i did a few months back my 5lug convertion and for best performance of it ,i know i need to change my master cylender. the ??? is which can i use. SI or typer R or GSR ???
Re: what master cylender will fit on my ek hb ? (Spoon1)
First you DON'T NEED to change your MC. All a bigger bore will do is take less pressure to engage the brakes.
If you want to change the MC, any 99-00 Si will do or 96-01 Integra will do.
CX MC is 13/16th. Si is 15/16th as are some tegs. Other tegs are 1"
Re: what master cylender will fit on my ek hb ? (Trey)
the reason i ask is cause i was told that do to the mc was design for drums in the back ,and cause of that it wouldnt perform to the best do to now having rear disk . while the integras or si are ! and also take in mind the way the lines going to the MC are vent and which will line up to it !
[Modified by Spoon1, 3:53 AM 3/31/2002]
Re: what master cylender will fit on my ek hb ? (jdm_latino)
The MC isn't the problem. You need to swap the porportion valve with one from an non-abs 99-00 Si. That will take advantage of the rear disks.
ok , they made the SI with non-abs ??? and if then i should enquired from the dealer a proportion valve for a 99 SI non -abs
thanks for the link!
Integralove00
09-10-2006 08:59 PM
