G2 swap b18C, ECU wiring.
Does any one know the pin outs for this ecu?
Do you have to run a second 02 sensor, and do you use a 02 sensor with 1 wire on it (i have no idea what 02 sensor is called), or a newer 02 sensor with (i think) 4 wires?
Also i notice that on the back of the b18b block that there is 2 wires? Is this the power steering pump switch. If so, on the ECU map, there's conflicting issues with these wires and the 02 wires?
WHAT DO I DOOOOO, is there any good reference sites for this swap besides http://www.g2ic.com/
Thanks
Thanks
bulgyh
06-27-2015 08:12 PM
